Upgrading plans
Lcucumber
If I upgrade to a more expensive plan will I loose my rewards?
1 ACCEPTED SOLUTION
Accepted Solutions
MrSpock
@Lcucumber no your rewards will be fine as long as you are upgrading sometimes you will lose a promo if you downgrade depending on the promo
MrSpock
iliketotalk
@Lcucumber  no worries for an upgrade 😀
@Lcucumber if you have Autopay enabled  and try to upgrade to more expensive plan, try to do a manual payment the first time, Autopay sometimes have problems with plan upgrade.   But after the first manual laod, the rewnewal after with Autopay should be ok
Also, make sure you understand thr difference between Change plan now and Change in the next rewnewal date and pick the one you really need.
