04-25-2019 05:24 PM - edited 01-05-2022 04:36 AM
I just joined public mobile on Tuesday and I noticed how the data addons are more expensive than lucky mobile and I don't understand why.
04-25-2019 07:08 PM
Ok
04-25-2019 07:05 PM
@coolvehiclefan they're not the same product. The cheaper priced product/service expires each month, while the Publilc Mobile version never expires; there is additional value in that feature. Get the plan that suits your needs.
04-25-2019 07:03 PM
Makes sense
04-25-2019 06:38 PM
@coolvehiclefan wrote:I just joined public mobile on Tuesday and I noticed how the data addons are more expensive than lucky mobile and I don't understand why.
Like @zfx said, Public Mobile Canadian Data Add on is very expensive however with Public Mobile any Canadian Add ins DO NOT expire as long as your Public Mobile line is in Active Status. So yeah you could have those add ons on your account till all used up, even if it take you years to use them
04-25-2019 06:22 PM - edited 04-25-2019 06:23 PM
Yes, it is more expensive than Lucky Mobile, but all remaining unused data can be rolled over to the next month and then the following month and so on... till you use them all up. Which is more flexible IMO, especially when you have a cheaper plan and don't use data that much just in case of certain unexpected needs...
04-25-2019 05:54 PM - edited 04-25-2019 05:55 PM
Yea
04-25-2019 05:54 PM
Yes that question does get asked quite a bit here..the data add on is way more expensive than the competition. I guess every carrier has their pros and cons.
04-25-2019 05:29 PM
I'm on their highest 3G data plan with 8.5gb and I was only curious as to why lucky mobiles prices are cheaper and u get more data for $5 less than public mobile at 2gb.
04-25-2019 05:26 PM
@coolvehiclefanI would also like to know the answer to that question.![]()
04-25-2019 05:26 PM
@coolvehiclefan - The pre-package plans are a much better value if you need data. If your current plan doe not have enough, it might be better to bump up to a plan with more data. If you only need a little more every now and then, the data add-on never expires, so...
