NO Data
Sandycrosb13
Since I updateded to the six gig plan I have no Data
edit by comptuergeek541: customer info removed
Triguy
There have service related issues with subscriber's account when they have made plan changes.  You will probably need to contact a moderator.
Moderator can be reached at
Jackhyf63
not sure why it would stop working. Make sure you have the correct APN settings that are found here: https://apn-canada.gishan.net/en
Did you have data from here before you upgraded?
Maybe restart the phone.
geopublic
@Sandycrosb13  Please remove your phone info. This is a public forum. Is the issue just data can you make/receive call and texts?
