04-09-2024 12:47 PM
It’s keep saying SOS when I put my sim card in my phone like public mobile block my phone from accessing the service because when I put it in a Samsung it’s work fine and I know my phone it’s unlocked I bought it from apple it’s a iPhone 15 pro max .. like can someone from there team can respond and fix it like the service it’s really bad with public mobile the worst ever definely not recommended to anyone can even talk to someone on the phone … disgusting
04-09-2024 12:56 PM
HI @Camill
does the sim card works on another phone?
if it works there and just not your iPhone, check if it is blocked
https://www.devicecheck.ca/check-status-device-canada/
makes sure you put in the correct IMEI, you should have 2 IMEIs, put in the correct physical one if you use physical sim. If you are not sure, check both IMEIs
you can also ask agent to help and check why it wasn't working
please submit a ticket with CS Agent using this Chatbot link: https://widget.telus.tiia.ai/publicmobile/publicmobile.html Type the question "Submit ticket", Then click the following in order: "Contact Us" , "Other", "Log In".
If any issue with ticket submission, you can submit by direct message:
