06-04-2025
04:28 PM
06-04-2025
09:52 PM
computergeek541
06-05-2025 01:10 PM
Hello @ KB2008
Please use this link to the Public Mobile Chat Bot which will direct you to creating a trackable ticket.
06-04-2025 05:05 PM
what make / model is your cellphone ...just to check if it'll accept a Public Mobile esim. You might just need to use a hard sim instead.
06-04-2025 04:46 PM
Ask PM to help, Since you cannot properly login, you won't be able to open the preferred Chatbot ticket. So, you will need to message them here:
06-04-2025 04:32 PM - edited 06-04-2025 04:33 PM
@KB2008 Sorry no live support for public mobile , customer service is all online messaging. But first check phone settings and ensure eSIM is set to primary or if iPhone you toggle on “turn on this line “ and reboot the phone maybe even a network reset . Also be sure to remove old carriers sim first to before you do so . If still no luck you can message support
Here @KB2008
