When you have data from a monthly plan and a one-time add-on, which one gets used up first?
axk165
Hello all,
I registered and activated my Public Mobile account with a plan that includes 1GB of data per month.  In addition to this plan, I also received a 5GB one-time data add-on for purchasing the SIM card on June 1 and activating my account before the 16th.  When I enable and use my cellular data, will it use up the data from my monthly plan first or will the one-time add-on data be used first?
Thanks in advance.
geopublic
@axk165 wrote:
Hello all,
Thanks in advance.
@axk165  The monthly data always gets used up first. The addon only kicks in when you don't have any monthly data left.
Dunkman
@axk165
The data will come from your monthly plan first, then if that runs out, your one time add on data will be used.
@axk165 wrote:
Hello all,
Thanks in advance.
The data in the base plan should always get used first.
Alex888
@axk165 It will always use your monthly plan data first and roll over the addon data.
