When buying an add on is there an option
CountyDownIeUk
I hear that the purchase of an add on is no longer 2 steps and you can buy the add on and use your auto-pay set up to fund it.
Questions:
Is there an option to fund the purchase from your balance?
Using your auto-pay set up to fund, does the auto-pay switch need to be “on” or will the purchase go through with it “off”?
@Yummy wrote:
How can autopay pay for your add-on?
You have to have funds on your account first and then purchase add-on.
Autopay is used to pay for your renewal.
If you expect to 'purchase' add-on First and then expect autopay to cover the cost I doubt that will ever work.
So you would buy 2-3 add-ons, rack up a bill to $50 and then expect autopay to cover it? And what if you use all your add-on before renewal day and then port out number or suspend service? Who is going to pay those $50.
No, my friend. Money up front and then go to play.
Two step is gone.
hairbag1
You can buy an add-on using your credit card, by dialing 611...you do need your pm pin number.
I'd assume you could do it via self-serve as well.
Yummy
will13am
The add-on payment is taken from account funds first if there's enough available to cover the cost.
