What’s Wrong?
Chenhhabc
I did not use my phone at all for the whole June and the first 15 days of July this year due to my being away from Canada on holiday. However, to my surprise, when I checked my “Usage History”, I found records of Outgoing Calls of the same number (647-580-4001) every day during the period that I mentioned above. Why did these recordings happen?
Priority
This is 100% normal. I have an Account which I don't use at all and it says the same thing in the Usage History, even though that SIM hasn't been in a phone since the change to EverSafe ID back on May there is multiple recordings/records to the same exact number you've posted about.
@Chenhhabc   this is a voicemail number.  People cannot reach you and got routed to the voicemail, usage log will shows for calls like these
abtest
@Chenhhabc- That is Public Mobile's voicemail number.
