3 weeks ago
I chose the wrong Sim card option when I signed up. I need my account changed from esim to sim.
3 weeks ago
buy a Public Mobile sim card from a Telus or Koodo or Mobile Klink store or Amazon.ca first.
Then message PM and ask them to change the sim type and update the sim card number for you
Since you cannot properly login, you won't be able to open the preferred Chatbot ticket. So, you will need to message them here:
