What phone is compatible
CC01
I
i never had a cell phone and I’m a bit lost.  Can anyone recommend a cell that is compatible with public mobile and the cheaper the better for me
thanks
carole
11 REPLIES 11
MrSpock
@CC01 hi it might be best if you pick one that you ike and then come back here and ask 😀
mydoghunter
Costco has a good unlocked phone for under $200 in store.
Motorola G Play 32 GB Unlocked Smartphone, Misty Blue | Costco
CC01
I like the Samsung Galaxie ones…some of them are reasonably priced.  Thank you for taking the time to help.
carole
MrSpock
@CC01 yes they are nice and should be good here just check if you find one 😀
@CC01   which exact Samsung Galaxy one you want?
Generally speaking, if it is a phone sold by Samsung Canada, it should work.
But f you are buying phone that import from another countries, a different regional variant, it might or might not work depends on the model
What is your price range? we can suggest some good ones for you
CC01
Up to 300 Canadian dollars
@CC01   Both A13 and A32 are solid choice
The A3x should be a higher model but A32 has been out for 9+ months .  A13 just came out not long so spec-wise is very similar.  But A32 has a better camera
@CC01
There was news that Samsung is having problems selling the “A” series phones.
Their warehouse are overstocked so there will be a promotion to sell them fast.
I would suggest you look the Samsung Galaxy A13. They are currently selling for under $200 but it will go down in price.
Higher models will have all the bells and whistles which will be too confusing for you with all the Settings adjustments.
CC01
Samsung galaxy a13 5g 6:5 inc unlocked 64 gb
this one should be okay?
is 64gb good?
so this one should be okay?
