2 weeks ago
- last edited
2 weeks ago
computergeek541
I’ll be in the US for just under 2 weeks and am wondering how this works and what the best option is.
2 weeks ago - last edited 2 weeks ago
@Emabean you are on the new reward plan? Yes, redeeming from points is usually 20% cheaper than buying it with meony
If you have enough point, just login to My Reward and pick the US roaming add-on and wait 24 hours for them to process.
Please note that once they processed your request and added to your My Account, it will start counting the 10 days, 240 hours, expiry. So, you would likely redeem it the day before your trip
2 weeks ago
@Emabean hi that would depend on your needs,here are the packages available 😀
10 day packages
Important: As of February 22nd, 2022, some United States (U.S) carriers will begin turning down certain 3G/HSPA networks in the U.S. As a result, some customers using U.S. roaming add-ons may be impacted by differences in coverage or service quality (including 9-1-1 calls) when roaming in the U.S. This shutdown will not impact your service in Canada.
10 day packages
2 weeks ago
@Emabean hello to add to above suggestion these addons start as so as you purchase them so wait until you need them, also buying an addon is a 2 step process,first you put money in your account then go back in and buy the addon
2 weeks ago
Thanks! Do you know how it works to buy from rewards points?
2 weeks ago
Thanks, that’s what I needed to know!
2 weeks ago
@Emabean since you are going on 2 weeks but PM roaming are all 10 days term, if you anticipate you will be using a lot of data for the full 14 days, you might want to buy local data instead, it is cheaper and give you more data.
But the drawback is that people cannot reach you via your PM number or you cannot send text. There are different kinds of workarounds (easier for voice but hard for text) . Let us know if you want to explore other option
