06-23-2022
10:04 AM
06-23-2022
02:46 PM
computergeek541
Bought a subscription yesterday. Unable to log in because user name is unknown. How can it be reset or found out?
My Account
06-23-2022 10:11 AM
Usually you log in into your account with registered email.
Did you ever created self serving account?
Did you activate in store?
06-23-2022 10:08 AM
@Yasuko5 did you activate in store? If you did, usually the store agent won't setup the My Account for you. Go back to My Account page, and click Create account (https://selfserve.publicmobile.ca/self-registration/ )
If you activate online yourself earlier and somehow cannot login now, open ticket with PM Support
1. For faster response (2-48 hours), Click on the bubble in the lower right to request CS Agent assistance, or use this direct link: https://publicmobile.ca/chatbot.
**Start with typing "Forgot Login Information", click "Contact Us", click "Click here to submit a ticket".
2. Or Send a private message to the CS Agent here: https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
06-23-2022 10:06 AM
@Yasuko5 Hi did you activate in store if you did you must set up a self serve account
