What happens when I upgrade from 3g to 4g
Jasonpenny
I have just upgraded my plan from 3g to 4g.   What happens? Do I get a new sim?
torontokris
You were always on the LTE network just throttled to what is labelled as 3G speeds or 3mbps.
Within a couple days you will be on what's labelled the 4G speed (still on LTE network) and throttled to 100mbps. Enjoy
HI @Jasonpenny   No, no new sim needed
You just request plan change.  After the plan is upgraded, wait 48 hours and you should see the new speed there
Same sim card , same phone, you don't need to do anything to get the new speed.  Maybe one thing, make sure your network type is either Automatic or 4G or LTE
dabr
@Jasonpenny   Faster data speed (and more cheaper data if selecting $40/15GB or $45/20GB), however, the change in speed will take about 48 hours to become effective.
HALIMACS
Nope, @Jasonpenny , the SIM card doesn't change - Public Mobile just upgrades the service on their end.
You just get faster mobile data than you did on 3g.
Welcome aboard!!!
hycm53
@Jasonpenny wrote:"I have just upgraded my plan from 3g to 4g.   What happens? Do I get a new sim?"
No, you don't get a new sim card.
