10-07-2022 02:02 PM
I can no longer access my account. Can't log in, my phone no longer works. Can reset password because it's not sending any resets to my email. Please help.
My Account
Service
10-08-2022 02:53 PM
If you would like to award the solution to @dust2dust for helping your way along to a solution then you simply go to the little arrow thingy on the right side of the post to unmarked your own post as the solution and then choose the appropriate post that helped you to a resolution.
10-07-2022 05:57 PM
Please update us on what comes out of this. There are a couple possibilities and that's what we were trying to nail down.
10-07-2022 03:07 PM
@dust2dust I tried the number, it says my account has been temporary suspended. Trying to iron this out with support right now. Wife told me she didn't get any SMS payments notification to indicate missing payment. Again, thanks for your help.
10-07-2022 02:37 PM
@dust2dust wrote:@esjliv- They can't log in. Excellent ideas the rest of the way. Hopefully the OP will keep us updated.
Yes, I know @dust2dust :). But since you provided them the 855 to check this, then I didn't feel the need to repeat it.
10-07-2022 02:28 PM
Please try the toll free number from earlier. Do you have an original box that the phone came with? That should have the IMEI on it and you can check the blacklist status mentioned earlier.
10-07-2022 02:26 PM
We had this account for 5 or more years. She's at work without the use of her phone which is a safety concern to me. If it was a problem with the phone than i can understand swapping sim card to another phone but right now I can't even access her online account.
10-07-2022 02:24 PM
10-07-2022 02:21 PM
So she has been able to use her phone the past 90 days without issue. How recently did your wife activate @jen_e ?
If the Account is showing Active status, try 1 or more of the below:
- restart phone
- toggle into and out of airplane mode
- perform a Reset of the device's Network Settings
- move your sim card to another phone to see if services works to see if services work
- Check if your phone is blacklisted (never know...) here: https://www.devicecheck.ca/check-status-device-canada/
Check for outages in your area:
https://www.telus.com/en/on/outages
Public Mobile Representatives customer support agents (CSA) can be contacted by either two methods, found here:
10-07-2022 02:14 PM
Thanks for the info @dust2dust
10-07-2022 02:13 PM
Click on the SIMon chatbot link down below to find your way to submitting a ticket.
In the meantime, you can dial 1-855-4pu-blic and enter her number and listen to what it says.
Can you answer whether her credit card might have been compromised recently?
10-07-2022 02:09 PM
is there a support person that can PM me to resolve this issue?
10-07-2022 02:07 PM
If she been suspended for 90 days then why has she been able to use her phone for the last 90 days.
10-07-2022 02:06 PM
This is my wife's phone, she is at work and she said she no long have access to any phone communication (phone, internet). She didn't not get any warning of payment issues... I would like to log into her account and rectify the situation but I can't even do that.
10-07-2022 02:04 PM
@jen_e Did you let your account pass the 90 day mark without renewing?
10-07-2022 02:03 PM
@jen_e wrote:I can no longer access my account. Can't log in, my phone no longer works. Can reset password because it's not sending any resets to my email. Please help.
Has your account been suspended for 90 days? If so, your account has been closed.
10-07-2022 02:03 PM
What recording do you get when you dial 611? Did you possibly deal with a credit card problem recently?
