What does Add-on "1000 U.K. Long Distance Minutes" mean?
Astralhunter
 Will be I able to use my phone (the same SIM card, phone number) in UK as  I use it in Canada?
golfball
No. You will be able to call someone in the UK from Canada. The only country where roaming is supported is the USA after purchasing an add-on.
HALIMACS
@Astralhunter
it means while you are in Canada with your device, you will be able to call the UK up to 1000 minutes.
These add-ons remain on the account until they are fully consumed, and do not expire.
Public mobile has no service option available for use outside of Canada and the US.  If you’re looking to use your device outside these countries, your best to purchase a prepaid Sim card upon arrival.
pkaraa
No. those UK minutes has to be originating from Canada.
pmva
@Astralhunter  No.  It will allow you to call a UK phone number for 1000 mins.
