10-25-2022 12:36 PM
Im in need of only half a point to get more data... What are the easiest ways for you all to get points fast
Rewards
10-25-2022 01:06 PM
As any 'point' system - the more you spend the more 'perks' you will get. If you select the most expensive plan and buy a ton of add-ons you will get a lot of points. Now, is that reasonable/doable it is up to you.
10-25-2022 12:51 PM
Great thank you
10-25-2022 12:51 PM
Thank you really appreciate it
10-25-2022 12:51 PM
Thank you I appreciate that. Unfortunately I'm low funds atm but I'll keep in mind to add extra when I do so this doesn't happen again to me lol
10-25-2022 12:49 PM - edited 10-25-2022 12:50 PM
Only way to get more points is to post or help out other members with their issue or get friends/family to join PM.
You can also try adding more money (5%) into your account and will remain a credit for the next bill.
10-25-2022 12:45 PM - edited 10-25-2022 12:48 PM
Sorry there's no quick and easy way.
All you can do is pay your renewal bill or purchase an add on to get more points, fast.
10-25-2022 12:45 PM
Community involvement and referrals. Everything else is sort of fixed (how much you get with every renewal, loyalty).
