10-19-2022
09:20 AM
10-19-2022
05:11 PM
computergeek541
Hi my name is Jasmine. My account and phone no is active. Outgoing calls can be done. But incoming calls goes immediately to voice mail. No issues with phone. How can I solve this ?
Service
10-25-2022 12:46 PM
Thank you
10-22-2022 07:10 AM
Hi I tried the sim with other phone and the problem is solved. Thanks for the help
10-19-2022 09:39 PM
@Jazmin11 let us know how it turns out with changing the network to 3G Only. Check if the phone connected to the network at all and how many status bars.
Another phone to test is to put your PM sim card in another phone, this would force sim provision and could resolve the problem .
If it still fails with incoming calls, open ticket with PM Support:
1. If you have access to My account: At https://publicmobile.ca/chatbot.
2. If you don't have access to My Account or have trouble with Chatbot: Private message CS Agent at:
10-19-2022 09:31 PM
Yes the same no
10-19-2022 09:30 PM
I will try this for sure
10-19-2022 09:29 PM
My account is active thatswat I am able to make outgoing calls
10-19-2022 09:28 PM
10-19-2022 10:16 AM
@Jazmin11 , if your account is inactive, nothing would work. Since you report outgoing calls working but incoming calls going to voicemail, that potentially indicates a failed number port or one in progress. Another possibility is that call were errantly forwarded to voicemail unconditionally.
10-19-2022 09:29 AM
Did you port your number to PM?
When did you join PM?
What number callers see when you call them? The one you picked when signed up?
10-19-2022 09:27 AM
@Jazmin11 hi go into your settings and manually switch to 3g in network setting that should help with calls
10-19-2022 09:23 AM
@Jazmin11 you had a chance to login to My Account and confirm the account status? If it shows Suspended, you should see another button "Reactive my plan". Click on it and follow the prompt to make a manual payment that way. (Yes, you might have setup pre-authorized payments, but that could fail sometimes for any reason)
