02-27-2017 05:20 PM - edited 01-05-2022 01:46 AM
03-21-2017 04:40 PM
Thank you @ToniCipriani, I'll be responding to your PM
03-21-2017 04:35 PM
02-28-2017 12:05 PM
@sheytoon, these are very useful reference sites. Going to add them to the bookmark library.
02-28-2017 07:58 AM - edited 02-28-2017 08:00 AM
@ToniCipriani
If Public Mobile was giving out new numbers, they would have to be from the Telus assigned pool. Your original Fido number wouldn't be in that pool.
You can see number original number assignments here:
http://cnac.ca/co_codes/co_code_status.htm
Click area code on left side. Your number should be listed under Fido (or Rogers). Use the other link I posted to view current provider of any phone number.
02-28-2017 02:16 AM
@sheytoon wrote:
You can check current provider of a number here:
http://freecarrierlookup.com/
Though it won't distinguish between Telus and Public Mobile.
Thanks for that. I've never seen that site before.
02-28-2017 02:05 AM - edited 02-28-2017 02:09 AM
@ToniCipriani wrote:
@SDO8 wrote:As long as your incoming & outgoing talk, text, and data are working fine, I wouldn't worry too much. Test it with your friends if you want to be sure. It has happened before, but there's not much you can do to preemptively stop that kind of uncommon error from happening. Simply be prepared to contact the moderators for help if necessary. Contact info here:
Nothing's wrong with my phone, everything still works. I'm just surprised the caller was able to tell me what carrier I'm on, even though my number exchange is with a different carrier. Was worried was those phone recording phishing scams trying to defeat voice passwords.
A regular subscriber would not know which carrier you are on, unless that information was provided by the cell phone carrier (for the sake of troubleshooting). She can make an educated guess based on the exchanges that are assigned by CNAC, but with number portability, the average person would not know which carrier you are using. The person would have to work at a cell phone carrier to have access to that information, or have that information provided to him or her by a carrier.
People do sometimes give out wrong phone numbers or save them incorrectly in their phone's contact lists.
I'm going to take a wild guess that Fido could be the culprit here. I say that because they are the original carrier, and your phone number would normally be part of their block of numbers. Fido may have mistakenly assigned your phone number to one of its customers. Telus did that exact thing to me after I transfered my number over to Rogers - Telus assigned my number again by mistake and were force to change the other person's phone number because of their mess up.
02-27-2017 10:14 PM
02-27-2017 10:05 PM - edited 02-27-2017 10:05 PM
02-27-2017 09:14 PM
02-27-2017 05:47 PM - edited 02-27-2017 06:21 PM
