06-24-2022 04:23 PM
Tried to use for 2FA. It worked instantly on my previous provider. It did not work here and i had to change my 2FA. Tried to send twice but did not receive anything.
Sometimes happens with other 2FA SMS even when I was on other networks, so not sure if this basically happens on any network?
Service
06-25-2022 08:14 PM
CRA second factor works ok for us. You can have it texted or by a recorded voice. BUT some times it can take quite a few minutes before it is received. You, know the feds are not that quick with anything other than carelessly spending our money on stuff that is no help to us. 😁
06-25-2022 07:45 PM
It can take up to 7 days for some 2FA texts to start to be recieved from certain senders for account security.
06-24-2022 04:29 PM
@bunnykin Hi did you recently activate your account? It can take 3 or 4 days for companies to verify your 2FA
06-24-2022 04:27 PM
HI @bunnykin did you just join PM and just ported your number into PM?
if that is the case, it is normal for 2FA to start coming 3 to 5 days after poring. The system needs time to learn that you have changed the provider and some system purposely add the delay in case of SIM fraud.
