Want 2 numbers on my account, is that possible?
michaelbarker54
jordan92
There is an option to have another phone number through apps in the app store. This would generally require data to receive texts and phone calls, but it could be preferable depending on your use case
hairbag1
Nope...each account needs a separate sim card and a different email address. You can use the same credit card though...if that helps.
@michaelbarker54
Unfortunately No, only one account/email address. You will need to create another email for the second account/line.
@michaelbarker54
If you meant you want to manage multiple numbers on 1 account, like family account,No.  One number on one account.  You need another email to start another My Account
