07-03-2025
01:32 PM
07-03-2025
04:35 PM
computergeek541
My wife is changing from a Telus pay and talk to P M, on average how long does it take Telus to send the “ok to cancel” text yo her phone?
07-03-2025 03:06 PM
@JeffWilford wrote:Thanks, but the issue is she has been waiting 20hrs for the text so she can reply ok, how long should it take got her to receive it do she can say YES and continue on with activating her PM account, thanks
Public Mobile’s protocol for porting issues is that you submit a ticket. The phone number the other member sent you is for Koodo and Telus only.
The Public Mobile chatbot is currently unable to create trackable tickets for members who are unable to log in. So for this reason, please use the following link to contact customer service.
07-03-2025 02:29 PM
hi @JeffWilford
simply call the number I sent you and the team will sort it out
07-03-2025 02:25 PM
07-03-2025 01:41 PM
hi @JeffWilford
don't send ok to cancel, you reply yes to the port authorization text and account will be closed after
for your port status, PM porting support team can help. I have sent you the porting support team number. Please check your Community inbox (https://productioncommunity.publicmobile.ca/t5/notes/privatenotespage), check for the number and call
07-03-2025 01:37 PM
As long as she says YES to the text within 90 minutes, wait of the name Telus on the top of the phone screen go to SOS. Then once it's SOS, it means the number has been transferred. She can then take out the Telus SIM and insert the Public Mobile SIM. Then reboot the phone.
07-03-2025 01:34 PM
@JeffWilford wrote:My wife is changing from a Telus pay and talk to P M, on average how long does it take Telus to send the “ok to cancel” text yo her phone?
Once the port to Public Mobile is successfully completed, your Telus account will deactivate automatically. No need for you to cancel.
