Calling out denied
Flask
Everytime I try to make an out going call it says call ended right away.
edited by computergeek541:  edited category label (discussion is unrelated to My Account/self serve account issues)
Chalupa_Batman
Hello @Flask
Which phone are you currently using? Side note, have you checked your account to see if your payment is up to date?
hairbag1
@Flask
if your plan includes only a limited amount of calling minutes, you could have run out of time. In that case you can get a Canada wide calling add-on with 500 minutes for $5.
Alternative is to upgrade to a plan with unlimited Canada wide calling as most plans offer that now.
hi @Flask
you are not on $15 or $13 plan, right?
try reboot the phone , and Reset Network Settings on the phone.  Should fix it
