WI-FI Calling
waynecole
I have a Samsung Galaxy S20 FE 5G.
Trying to Access WI-FI Calling feature, but no luck.. Does not come up anywhere.
Is it My phone or Plan?
Thank you
2 REPLIES 2
@waynecole   sorry, no Wifi Calling
for now, PM just rolling out VoLTE.
PM is a no-frills provider and usually will only provider the minimum features.  I highly doubt they will introduce Wifi calling.  If this is a much needed feature for you, you might want to check with Koodo or Telus instead
umnikke8
Public Mobile doesn't support Wifi Calling and it will be a long time, if ever that they do support it.
