Voicemail
cyiza
How can I disconnet my Voicemail?
It's include in my plan but I don't need/want It.
Yes, it is great trick but be aware that Nobody can leave vmail after you apply it. Vmail gets deleted after 10 days anyway.
cyiza
Very helpful!
@cyiza   You cannot
But there is a workaround to make it seems like it was disabled:
on your dial pad dial: *004*8080000000#
This will cause all calls to either ring forever or get fast busy at the point they normally would have been diverted to the voicemail system.
To reset it back to defaults, dial ##004#
