02-14-2022 08:34 AM
I wanted to know if I can retrieve a voicemail from November 17th, 2021. I require it to start a legal case. Are you able to send me a copy?
02-14-2022 01:14 PM
response was not related to the question asked
02-14-2022 12:21 PM
If you listened to the message and didn’t press 7 to delete. The message will be archived.
If you pressed 11 to delete then it is long gone.
02-14-2022 10:43 AM
02-14-2022 08:48 AM
Unfortunately pm's voice mail service only saves messages for 10 days unless you manually save them yourself.
