05-04-2020 09:57 AM - edited 01-05-2022 10:38 AM
When I go to get my voicemail my screen has a message saying " Error performing request Unknown Error" At the bottom of my screen I have a tab that says "Dismiss". Has anyone had this problem?
Joining Public
10-01-2020 11:56 AM - edited 10-01-2020 11:57 AM
@angieprokopetz If tapping your voicemail button on your iPhone does nothing or gives an error this issue is usually caused by your voicemail number not being programmed correctly into your iPhone.
You have to set up your voicemail number in your phone settings. The number is your area code -580-4001.
10-01-2020 11:47 AM
10-01-2020 10:18 AM
@angieprokopetz can you explain the issue you're having so we can try to help you?
10-01-2020 10:04 AM
I have the same error. Calling my number like suggested did give me access to my voicemail, but I still get the same error on my phone. But I appreciate the help in getting to my voicemail the old way!
05-04-2020 11:17 AM
@Ronmac24 Glad to hear that issue was easily and promptly fixed. Welcome to PM and enjoy savings. Happy Monday.🙂
05-04-2020 10:28 AM
Thanks. Restarting the device fixed my voicemail problem.
05-04-2020 10:22 AM - edited 05-04-2020 10:24 AM
@Ronmac24 wrote:Thank you. The fix was as simple as restarting my iPhone.
You might be familiar with other forums where the thread starter "closes" the thread. Here, the Accept as solution has some meaning. Perhaps click on the 3 dots in the upper right of your solution post and remove the solution and then re-click the button on Dunkman's reply.
05-04-2020 10:15 AM
05-04-2020 10:05 AM
It is likely still setup to call the voicemail of your previous provider. Try resetting/restarting your phone.
You can dial your own number or one of the voicemail mail numbers (such as area code + "580-4001". And optionally add this number to your speed dial.
05-04-2020 10:03 AM
05-04-2020 10:02 AM
05-04-2020 10:02 AM
More details may be helpful. Did your voicemail work before? New problem versus old? Everything else work? talk, data and text?
Maybe try rebooting your phone. Network reset?
05-04-2020 09:58 AM
@Ronmac24 What's the make and model of your phone? Thanks. Stay safe.
