Voicemail
TjK1
New customer, how do you access voicemail
edited by comptuergeek541: changed category (discussion isn't related to Community)
2 REPLIES 2
hi @TjK1
check voicemail FAQ here:
https://www.publicmobile.ca/en/get-help/articles/voicemail-faqs
but generally press and hold 1 and you will get to voicemail.
if that doesn't work, Reboot phone and click Reset network settings and it will program the key and try again
if still unable to get to voicemail, try calling one of the numbers on this page:
https://productioncommunity.publicmobile.ca/t5/Get-Support/Updated-list-of-Voicemail-Access-Numbers/...
