04-24-2024 10:00 AM
My phone shows a red dot as if I have a voicemail but I don’t as I have deleted it. How to get rid of the dot? Also, after I listen to voicemail and deleted the message how to exit from voicemail ? I don’t think it’s one of the options I heard . Thank you.
Service
04-24-2024 10:20 AM
Thank you powering the phone off then on worked!
04-24-2024 10:19 AM
Which model phone do you have? If iPhone, might be a visual voicemail issue.
To exit from voicemail, usually just hang up.
Here is some more information:
https://www.publicmobile.ca/en/on/get-help/articles/voicemail-faqs
04-24-2024 10:17 AM
@Joannedaigle You can try powering your phone on and off to see if the voicemail indicator will go off. I find that when I listen to my voicemail, if I exit too soon without saving or deleting the message it will still show me the indicator.
I usually just hang up when I'm done and then it will disappear. You can also check your notifications to see if something is checked in your phone settings.
04-24-2024 10:16 AM
are you using iPhone? Look like Live voicemail was enabled. Try to disable it and issue will be gone
