a week ago
Hi,
Can someone please help me with voicemail number not set when I hold the 1 to dial voicemail.
a week ago
Glad you got it resolved!
a week ago
Thanks, reset worked
a week ago
usually you just need to reboot the phone, then Reset network settings and the voicemail number would push down shortly
if that does not work, go to the Dialer , click Settings, look for Voicemail number and you can set it yourself. Use one of the number here:
