02-03-2024
03:26 PM
02-03-2024
06:19 PM
computergeek541
Hello,
My dad and I recently switched to Public Mobile and after a couple of weeks, we realized our voicemails aren't working. When we don't answer the phone call, the caller receives a hang up tone and the voicemail doesn't kick in. I can access the voicemail using the +16475804001 number. We also set it up and added our greetings
Appreciate the help!
02-03-2024 06:17 PM
Hi, I dialed that number, but it says that call forwarding service has been disabled. I was wondering how to enable it using the dial?
02-03-2024 04:37 PM
You have to set up voice mail very first time accessing it from your mobile device. After that you can do all other settings either through your mobile phone or any other phone calling access number.
If you have $15 plan this process will use your minutes.
02-03-2024 03:52 PM
Hey @Bhavik
His voicemail may have been accidently reset. Here's how to set it back up again.
https://www.publicmobile.ca/en/on/get-help/articles/set-up-voicemail
I can say this, over the past week or so there have been some issues reported of that you are experiencing. For me, when I dial 611 I get the same issue.
02-03-2024 03:31 PM - edited 02-03-2024 03:37 PM
Hi @Bhavik
Check the settings on phone dialer, check if the forward to VM when not available is enabled
Or you can dal #004#
If that does not help, have agent to reset the VM
please submit a ticket with CS Agent here:
