08-08-2023
01:36 PM
08-08-2023
02:14 PM
computergeek541
08-08-2023 05:42 PM
Instead of using the Voicemail section on your Mobile Phones Calling app, dial your own Cell Phone Number and it will redirect you to your Voicemail box where you can set up your mailbox, record your greeting, customize voicemail settings, and listen to your messages.
08-08-2023 01:45 PM
@Lunchbox are you trying to access visual voicemail? there is no VVM here. You have to access VM by press and hold 1 to connect
