Voicemail- No Visual Notifications
Marinela
Does anyone know what I need to do to get some kind of visual notification/ flag when I have a Voice Mail Message? Currently, in order to know if I have a voice message, I need to actually check my voicemail if there are any new messages. This is quite annoying because I have missed some urgent messages because I checked too late.
Any advice would be appreciated.
Thanks,
Marinela
10 REPLIES 10
@Marinela  - maybe you tried this already...but try - Turn on visual voicemail :
  1. Open the Phone app .
  2. At the top right, tap More options .
  3. Tap Settings. Voicemail.
  4. Turn on Visual voicemail.
OR -Activate Basic Visual Voicemail - LG
  1. From the Home screen, navigate: Apps icon. Voicemail. . ...
  2. From the Welcome screen, tap. Continue. .
  3. To continue, review the Terms and Conditions and then tap. Accept. .
  4. From the 'Enhance your experience with Premium Visual Voicemail' screen, select 'Subscribe to Premium' or 'No, Thanks'.
HI @Marinela
try to clear cache for your Phone App as well as your Text messaging app
Then reboot your phone
Timer
@Marinela
tried this Voicemail
and  How to Change Voicemail Notification
and rebooting device.
Marinela
I have a LG G7 ThinQ...and yes, notifications are ON.
Marinela
I should add LG G7 ThinQ...
Marinela
I have an Android LG G7. Notifications are enabled. I get badges for other apps.
@Marinela   It is likely a phone settings.  You might have accidentally blocked the notification for your phone or messaging app
what kind of phone is that?
Yummy
VMail notification icon should be On by default. I was not able to find setting to turn it on/off on Android.
What phone do you have?
@Marinela
Go to your phone settings and enable notifications in banner and badge.
What phone do you have so we can help you with the settings?
Marinela
Does anyone know what I need to do to get some kind of visual notification/ flag when I have a Voice Mail Message? Currently, in order to know if I have a voice message, I need to actually check my voicemail if there are any new messages. This is quite annoying because  I have missed some urgent calls.
I would appreciate any advice.
Thank you.
Marinela
