Voicemail Error message
J-gardener
I get this error message and cannot access my voicemail. Has anyone encountered this?  Know how to resolve it?
gpixel
@J-gardener
visual voicemail doesn't work at PM
Yummy
Did you try to access vmail box from other phone? If it works then there is an issue with your phone.
Remedy might be simple - reboot your phone or/and reseat your SIM (pull out, plug it back in).
darlicious
@J-gardener
Yes they have exactly....rebooting your phone should do the trick. See the solution here...
https://productioncommunity.publicmobile.ca/t5/Get-Support/Voicemail-error-message/m-p/788740#M52457...
@J-gardener   Try a phone reboot and try again
Also, try to  access your voicemail by calling yourself from a landline or another phone
