02-21-2023
03:15 PM
02-21-2023
05:37 PM
computergeek541
When I don't answer an incoming call my phone goes to the recording your call cannot be completed as dialed instead of to voice mail
Can anybody tell me how to get this fixed?
02-22-2023 01:56 PM
Thank you this was the solution.
02-22-2023 01:42 AM
@Arch772 Since you mentioned that calls do route to voicemail if the call is received while you are already on a call or decline the call, I'd suggest you:
02-21-2023 03:55 PM
@Arch772 check the call forwarding first, from. option in your dialer app or use the * code, would be a much quicker fix
but if you want to engage support, here you are
1. Please open ticket via Chatbot (need access to My Account): At https://publicmobile.ca/chatbot.
2. If you have trouble with Chatbot or you don't have access to My Account: Private message CS Agent at:
02-21-2023 03:52 PM
I am thinking it is a programing error is there anyway to get in touch with public mobile?
02-21-2023 03:41 PM - edited 02-21-2023 03:44 PM
@Arch772 you can use the option on the phone dialer or chexk this list, make sure Busy, Not reachable, No reply are set to Forward to your voicemail
https://www.publicmobile.ca/en/on/get-help/articles/call-forwarding
Add: As to the actual VM number, check this, pick one close to you
02-21-2023 03:34 PM
Mail box is setup and password works. It will go to voice mail if I am on the phone or decline the call
02-21-2023 03:33 PM
thanks @computergeek541 !!
02-21-2023 03:21 PM
Inappropriate content removed
02-21-2023 03:19 PM
@Arch772 you have setup your voice mail yet?
https://www.publicmobile.ca/en/bc/get-help/articles/set-up-voicemail
02-21-2023 03:18 PM
@Arch772 Have you tried to access your voicemail from your phone. Sometimes you need to initiate the voicemail box. The other thing to try is to logon to your account and set the voicemail password. That might initiate the voicemail box too.
02-21-2023 03:17 PM
@Arch772 Have you set up your voicemail yet ?
