Voice mail
Guy58
Hi. iPhone 13 running iOS 18.
I have people calling me and they don’t get the voicemail. I disabled the voicemail on the iPhone as Publix troubleshooting logs told me to. Still have a problem people report phoning and all they hear is a click click. Also sometimes I have a missed call and it doesn’t show up so I don’t think it’s the phone. I think it’s Publix network
7 REPLIES 7
Guy58
Thank you for your help
hi @Guy58 submit a ticket and ask PM support
Please submit a ticket with CS Agent using this Chatbot link: https://widget.telus.tiia.ai/publicmobile/publicmobile.html Type the question "Submit ticket", Then click the following in order: "Contact Us" , "Other", "Log In".
If any issue with ticket submission, you can submit by direct message:
Hey @Guy58
Settings, General, Transfer or Reset iPhone, Reset, Reset Network Settings. Then reboot.
Guy58
Ni
how do u get support to do that?
thanks for your help
Guy58
Hi
by reboot phone that means turn it off?
reset network settings - how do u do that?
yes iphone live is disabled
hi @Guy58 did you try Reboot Phone and Reset Network Settings?
And did you try your sim on another phone?
and when you said Disable Voicemail, you meant iPhone Live Voicemail?
will13am
@Guy58 , if you are experiencing problems with the calling feature, having support reset the account can help.  I have had it done before.
