Voice mail
01-09-2024 11:00 AM
Cannnot retrieve voice mails. Press 1 on key pad. Directs me to menu, setting, voicemail. Shows voicemail number not set up. Can't access to set up. Thought this was automaticly done by Public Mobile.
My Account
01-09-2024 11:09 AM
On your phone you have to set up voice mail number.
Go through settings, find where it says voice mail and enter one of available voice mail numbers.
VERY first time when using your voice mail you have to set it up using your mobile phone (it will use minutes if you are on $15 plan). Then any other time you can access it either through your mobile or any other phone.
01-09-2024 11:04 AM
an easy way to get that Voicemail setup is to click Reset all networks or Reset Network Settings on your phone
if that does not work, you can manually add the number yourself. Pick one from the list in this post (pick one in your area code)
