07-12-2022 10:34 AM - edited 07-12-2022 09:32 PM
Hello,
My friend bought a Vivo Y10 phone in China and is wondering if they buy a Public mobile sim card if it will work. Assistance appreciated!
Thanks
07-13-2022 12:50 AM
Looking at the specs, it appears to support many (most?) of the common 3G (for voice calls) and LTE (for SMS/MMS/Data) used by Public Mobile (Telus) in Canada: Vivo Y10 - Specifications (devicespecifications.com)
The Vovo Y10 supports 3G W-CDMA 850 MHz (B5), but not 1900 Mhz (B2)
it supports LTE-FDD 850 MHz (B5), but no support for any of the other common LTE bands used in Canada: 2, 4, 7
The phone also supports some LTE-TDD bands, but TDD is not used in Canada.
So yeah, as others said it may work, but service may be spotty...
07-12-2022 10:55 AM
I would suggest you remove the IMEI by using the down arrow in the circle top right.
07-12-2022 10:52 AM
I looks like the Vivo 10Y will only work on B5 for 3G but you need B4 for LTE.
Remember 3G frequency will be removed in 2025 in Canada.
07-12-2022 10:48 AM - edited 07-12-2022 10:49 AM
@danielvic Hi try willmyphonework .net I don’t see it listed,though Not my first choice
07-12-2022 10:47 AM
It would be a very poor choice for here. You might barely get some connection but it would be a challenge. Your friend might not appreciate you giving out the IMEI of their phone.
