Support
G740
I’m trying to activate a eSIM It’s not working.
1 REPLY 1
Neil11
You will need to contact customer service agent to fix your issue. Either via the following link:
If you are having a difficult time, then you can private message CSA:
Send a private message to CSA through the following link :
