Adding 1 GB of data to my plan
MisterWrong
So far I have 7.5 points so far. When I add 1 GB of data to my plan using 10 pts, will it become 1.25 GB of data per month since I currently have 250 MB? Also, is the addon permanent?
LegusY
Well-explained!
HI @MisterWrong   The 1GB add-on , like other add-on is a one time add-on, not per month
So, you add 1GB and it will stay there with no expiry date.  Once your regular 250 MB got used up, PM will start taking it from the 1GB add-on.  if it is not all used up when the next renewal comes, it will roll over to next month
MrSpock
@MisterWrong @Hi when you purchase your add on it will stay on your account until it is all used up
ShawnC13
Add-ons do not get added to your current plan. They are a one time purchase that stay on your account until fully consumed. As well I believe you need 15 points before you can redeem then to purchase something.
