06-06-2023 03:22 PM
We are getting some visitors from Holland over this summer for my son's wedding :-). They hope to stay for a month and asked me for a sim-card with a plan for just one month. I told them I will inquire with PM since I'm there too. Will it be possible to obtain a sim card, register it and add a plan which will not be renewed after one month? Or do I always have to add my credit card and then it will renew automatically every month?
Monday
05-14-2025 07:58 AM
06-06-2023 06:59 PM
Thank you. They have investigated that avenue but it’s a lot more in Holland where the plans are really cheap.
06-06-2023 06:46 PM
I'm late to the party, but have them check roaming options from their Dutch provider.
In a couple of weeks I'll have a friend over who currently resides in Switzerland, a country that doesn't have cheap plans compared to their neighbours. However, they mentioned that they are able to get a roaming option for Canada and the US, unlimited talk, text and 5G data (I think it might be throttled after 50GB?) for less than the equivalent of CAD40/month... About half of what the same features would cost here, if we are comparing as close as possible to apples and apples. Of course if they only need basic minutes and texts, then $15 is a better deal.
06-06-2023 04:07 PM
Thank you so much. It’s all clear now.
06-06-2023 04:05 PM
Thanks
06-06-2023 03:56 PM
Thanks. Nice and easy
06-06-2023 03:34 PM
PM used to only accept Cdn CreditCards, I don't know if that is still the case, but just to make you aware. In the meantime, get the SIMs ahead of time.
06-06-2023 03:25 PM - edited 06-06-2023 03:26 PM
@Dennis2109 Yes just activate sim on plan you want and then log in and turn off auto pay like this
Turn auto pay OFF/ON 3 easy clicks
06-06-2023 03:25 PM
@Dennis2109 you can use your card to help Activation and then disable auto renewal after
You can also buy Prepaid Visa and activate
9r you can buy vouchers from SDM/711/Shell/London Drug and activate but you will need support to help to activate with vouchers
