07-27-2022 10:10 PM
There is a very restricted (and rather odd) list of choices for the "City" when one is changing the phone number. I live in Uxbridge, ON, which uses basically two different exchanges in the 905 area code. My son just got a new phone and wanted to select one of those two exchanges for his phone number so that his friends would recognize it as "Uxbridge". However, Uxbridge wasn't even a choice. In checking the list of possible choices, I find that there are only 74 for all of Ontario. As somebody else pointed out, Mississauga, isn't there but Engleheart (population about 1700) is!
I'll swear that Uxbridge USED to be a choice but now my closest choices are "Newmarket" (which is actually long distance from here) or "Port Perry".
Why are there so few choices for all of Ontario? Is there a way to "petition" to get new cities added?
Joining Public
My Account
07-28-2022 02:00 AM
@softech wrote:Lots of choices, but Telus ONLY owns the exchange (364) 444. So, there obviously not many choices and likely all given out already. (the rest of those exchanges are owned by other carriers. Even Rogers and Bells do not have too many, but Rogers + Fido seems to own a bit more. The rest are owned by others smaller carriers)
I'm uncertain that Public Mobile can use exchanges assigned to Telus Integrated Communications as in the case of (365) 444-xxxx. These could very well be numbers assigned to a different part of Telus Communications. From what I've seen, phone numbers that can be used by Pubilc Mobile are assigned to Teus Mobility.
07-27-2022 10:34 PM - edited 07-27-2022 10:46 PM
FYI, the city choices are by where the rate centres are , not actually by the city boundary.
Also, the choice provided are based on the rate centres that Telus has its network on, of course also depends if numbers are available.
You know why Uxbridge is not a choice there? Uxbridge has the following exchanges
(289)- 394, 564, 581 , 595,640,852,
(365)- 245, 444, 526,533,587
(905)- 852, 862,904
Mississauga is a big city, so big that it is broken down in the 5 different local "rate centres"
Clarkson, Cooksville, Malton, Port Credit, Streetsville
Mississauga has five rate centers, left over from individual villages pre-dating its 1974 incorporation, with a different local calling area for each. Some are local to Oakville, some are not.
Ref: https://en.wikipedia.org/wiki/Rate_center
07-27-2022 10:18 PM
@TP626 - the numbers keep refreshing when you go into and out of the choice of numbers. So you are not seeing numbers you would like with any surrounding cities you are choosing?
Try keep refreshing and see if that helps.
A petition, well you could ask a CSA agent and see what they say.
Public Mobile Representatives customer support agents (CSA) can be contacted by either two methods, found here:
