Change plan
07-27-2022 07:46 PM
I have changed the plane , I changed the plan today from 15$/month to 41.25 $, but it's still showing old plan , I already have paid
Plans
07-28-2022 02:52 AM - edited 07-28-2022 02:53 AM
@Yummy wrote:Even if you did change plan Now, it will not show up immediately.
Check tomorrow..
Immediate plan changes show up immediately with the updated plan information displayed in the Self Serve account.
07-28-2022 02:52 AM
07-27-2022 08:11 PM
Check tomorrow..
07-27-2022 08:00 PM
after 24 hr just tried refooting device and is take up to 48 hr to changed.
07-27-2022 07:51 PM
@Aamir11 - did you choose to Change Plan Now, or change on your Next Renewal?
If you still see the funds in your Available Funds balance that you added, then it likely did not change. So go back and Change Now.
Note, if you Change Now, you will not be prorated any funds that was already prepaid in your current cycle.
07-27-2022 07:49 PM - edited 07-27-2022 07:49 PM
@Aamir11 hi sign out then clear cache and cookies,you can use a differrent browser in secret or ingognito mode , sign back in
