VOLTE?
02-15-2024 05:52 PM
04-11-2025 04:02 PM
02-16-2024 07:11 AM
@Yummy You can also check if VoLTE is enabled on an Android phone by looking for the IMS registration, try something like Settings > About Phone > Status > SIM Status and look for VoLTE/IMS registration.
Your phone can be LTE capable without being VoLTE capable/enabled. I have one such myself, it is supposedly capable but was not enabled on my previous (Tier 1) carrier. It would show LTE in the status at the top but the LTE would change to 3G on voice calls. VoLTE is voice over LTE, it does not necessarily follow that a phone capable of LTE is also enabled/capable of VoLTE.
Your test suggests to me that the phones are not VoLTE enabled (as well as being used synonymously with LTE in many cases, 4G can refer to a kind of 3G I believe, depending on carrier, but someone more technical than me would need to comment on that aspect).
SMS should still work after the Canadian 3G shutdown I would assume, the carriers have ways to send them without 3G. Think about the USA which shut down 3G in 2022. People there are still able to use SMS.
02-15-2024 08:51 PM - last edited on 02-16-2024 01:16 AM by Andu_S
@fixin wrote:
@Maribel19 - You will automatically have VoLTE on in the background, there will be no switch to turn it on like Rogers, but here are the comparable devices for VoLTE on Public Mobile:
- Apple iPhone 8 & above (iOS 16 & above)
- Google Pixel 4/4XL/4a/4a 5G (TP1A.220624.014 & above)
- Google Pixel 5 (TP1A.220624.014 & above)
- Google Pixel 6a (TP1A.220624.021.A1 & above)
- Google Pixel 6/6 Pro (TP1A.220624.021 & above)
- Google Pixel 7/7 Pro (TD1A.220804.009.A2 & above)
- Samsung S23 (AVK2 & above)
- Samsung S22/S22+/S22 Ultra (CWAI & above)
- Samsung Galaxy Z Flip4 & Fold4 (CWAC & above)
- Samsung Galaxy Z Flip3 5G & Fold3 5G (FWB1 & above)
- Samsung Galaxy Z Flip 5G (HWB1 & above)
- Samsung Galaxy Z Fold2 5G (JWB5 & above)
- Samsung Note20 5G/Ultra 5G (HWB3& above)
- Samsung A53 5G (CWB4 & above)
- Samsung S21 FE 5G (EWB3 & above)
- Motorola edge 2022 (S2ST32.71-71 & above)
- Motorola Moto g 5G (S2SA32.1-54 & above)
- Motorola Moto g power (2022) (S3RQ32.20-42-10 & above)
- Motorola Moto g pure (S3RH32.20-42-10 & above)
- Motorola Moto g stylus 5G (2022) (S2SD32.21-85-3 & above)
- TCL 303 (V9Q1K & above)
- TCL 30 XE 5G (DM9M & above)
- TCL 20s (9DI0 & above)
- TCL 30 5G (7FCU & above)
- Sonim XP10 Rugged Phone (10.0.0-01-12.0.0-12.25.10 & above)
- ZTA Blade A7P (Z6252CAV1.0.0B15 & above)
If you don't have any of these phone models and above, your current phone isn't compatible for VoLTE at the moment.
That list cannot be relied upon as it isn't complete. Also, a phone model being on the above list doesn't ensure that VoLTE will work either. If the phone has a version of software installed from a different a carrier, VoLTE might not work.
02-15-2024 07:14 PM
@Phil_Adelphus wrote:@Maribel19 So what does that mean for the S8 phone. They can't call someone
If the phone stays on LTE it is VoLTE enabled, if it drops to 3G it is not.
Is that a Reliable test?
As I turn data on I immediately see LTE even though I do not have VoLTE option in phone settings.
BUT as you pointed out ONLY after placing a call you can see actual status. So I see H+ (on S7) and G4 (on S10). What that means? And the most important question is: will SMS work after eventual 3G shut down in Canada?
02-15-2024 06:17 PM
It will still work in Canada until the 3G network is shut down which may be years away. It will have problems if travelling in the USA which has already shut down 3G and the 2G that people have been able to fall back on is scheduled to shut down in the USA on April 2nd. You can test if the phone is VoLTE enabled by turning off wifi, turning on cellular data and making a phone call. If the phone stays on LTE it is VoLTE enabled, if it drops to 3G it is not.
02-15-2024 05:59 PM
So what does that mean for the S8 phone. They can't call someone?
02-15-2024 05:57 PM
HI @Maribel19
S8 is for sure not VoLTE whitelisted with PM but 7a should be
02-15-2024 05:57 PM
@Maribel19 - Your Pixel 7a is ready for VoLTE but your Galaxy S8 isn't compatible yet.
02-15-2024 05:55 PM
We have Galaxy S8 and Google Pixel 7a
02-15-2024 05:55 PM
HI @Maribel19
All accounts are now enabled with VoLTE, however, not all phones are whitelisted with VoLTE on PM
Any phone on here are whitelisted, and I believe the newer phone on the same line of the models are whitelisted as well (so, S24 would be whitelisted as S23 is)
02-15-2024 05:54 PM - edited 02-15-2024 05:55 PM
