05-18-2024
12:22 PM
06-09-2024
11:03 AM
Dunkman
I'm trying to download my usage history from the last few months. But the download button doesn't seem to work, and hasn't for a few weeks. Is anyone else facing the same issue? Are there any workarounds?
05-18-2024 12:35 PM
hi @BestNickname yes, the button seems to have not working. But try using different browsers as it could also be a browser problem
if you still cannot download, ask support agent to help
please submit a ticket with CS Agent using this Chatbot link: https://widget.telus.tiia.ai/publicmobile/publicmobile.html Type the question "Submit ticket", Then click the following in order: "Contact Us" , "Other", "Log In".
If any issue with ticket submission, you can submit by direct message:
05-18-2024 12:25 PM
@BestNickname Can always ask support to retrieve it for you
submit ticket with support . using the chat bubble bottom right of screen
If that doesn’t work you can always send direct private message to support .
send a private message To CS_Agents
