After activation
SonnyHong1966
What settings do I need to change on my iPhone settings to make it work with public mobile?
2 REPLIES 2
@SonnyHong1966  If you have eSIM in phone settings ensure you have “turn on this line “ toggled on and reboot the phone or reset network settings see if that helps
wrote:
hi @SonnyHong1966 physical sim or eSIM??
generally you don't have to do anythi.g.  But make sure Carrier Profile is updated and you have the latest iOS.    And also Reset Network Settings on your phone
