Us roaming
05-01-2019 11:18 AM - edited 01-05-2022 04:41 AM
05-01-2019 11:44 AM
Yes added The correct bundle talk text and data and it showing up under my plan under add-ons. And I checked on my phone roaming is enabled. It is connecting to the T mobile network. Also rebooted several times.
But I’m still not able to text or talk in the United States.
05-01-2019 11:43 AM
05-01-2019 11:25 AM
@Salma1234 wrote:Purchased us bundle roaming, shows up under add- on
data works
but talk/text not working.
@Salma1234 Please make sure you’ve added a roaming Add-On that includes the service you are trying to use. You can verify what’s included in your Add-On by signing into Self-Serve. Also, make sure your mobile device has roaming enabled.
05-01-2019 11:23 AM
@Salma1234- If the proper plan is showing up, talk/text should also work. Hoping you have restarted the phone. Migh be able to use the lost/found phone trick. It could reset the plan (although it should not really be needed in this case).
05-01-2019 11:22 AM
data works
Make sure you enable Roaming on your phone. You might have to manually select network AT&T or T-Moble.
- « Previous
- 1
- 2
- Next »
