12-01-2023
05:08 PM
12-01-2023
06:52 PM
computergeek541
Yesterday I added the 15day data/talk/text add-on, paid for it, got the receipt, but it's not showing in my add-on list and the phone is not working in the US. I've opened a ticket, but thought I'd ask here just in case . Am I missing something?
TIA.
12-03-2023 09:04 PM
HI @Bfine
did you check the community inbox for agent's reply?
and did you try to connect to T-Mobile or AT&T? try both and one of them should work
make sure Mobile data roaming is enabled
12-03-2023 08:03 PM
I opened a ticket on friday. No response. I have also sent a couple of follow-up messages.
II've been stuck in the US with no data for 3 days now.
Any other suggestions would be greatly appreciated.
And, yes, roaming is on, and I've rebooted the phone many times...
12-01-2023 07:21 PM
did you open your roaming function when you using data?
12-01-2023 05:26 PM - edited 12-01-2023 05:27 PM
@Bfine reboot the phone or try from another device or check on the app instead . If you have been charged and it still doesn’t show up please submit ticket with support
send a private message To CS_Agents click
VVVVV Link below VVVVV
12-01-2023 05:12 PM - edited 12-01-2023 05:13 PM
hi @Bfine
maybe just browser cache, please use Incognito/private/secret mode on your browser to login My Account to confirm again
If same, please submit a ticket with CS Agent here:
And if you finally able to see the addon showing, then try manual connect to T-Mobile or AT&T
