11-07-2023 06:49 PM
Need assistance to connect to network
tried everything posted even reset the settings , turned the phone off and on
what else is there that can be done
i I need to speak to someone ASAP
11-08-2023 08:00 AM
Does it say unauthorized access when you login on the overview tab?
11-07-2023 08:01 PM
@NateFordy - all help is online here, either PUBLIC here on the community, or if you need Public support it is all through private messaging.
There is no number to call or anyone to talk to. What details can you provide us to help? Are you a new customer that just activated, existing customer for some time...how long...?
Is your account status ACTIVE in My Account or when you dial 611?
Check if your phone is blacklisted here: https://www.devicecheck.ca/check-status-device-canada/
11-07-2023 06:54 PM
best to start your troubleshooting here in Forum. Did you just start a PM account and ported over ? We need a bit more info.
11-07-2023 06:53 PM
Are you talking about getting your data working? If yes, check apn settings:
