Need help with Menu Item
Hollister
Hello, I was looking at the phone information using the following in the dialer:   *#*#4636#*#* to bring up a hidden menu. I accidently changed this menu item. Can someone tell me what it should be?
sheytoon
For future reference, you can set it to NR/LTE/WCDMA, which represent 5G/4G/3G respectively.
Other values represent network types that are not available with Public Mobile.
Hollister
@kb_mv
@kb_mv wrote:
@Hollister That just gives what the phone is set to (under network settings) for preferred network. Just go into your network settings and put it to whatever it was before you changed it.
Thank you very much! This worked!
kb_mv
@Hollister  The down arrow to the right of your red arrow can you tap that and set it To 4G/LTE or 5G by any chance . I’ve never saw a screen like that before so I don’t really know . But I would try that if it’s possible
adding @Hollister  worst case you could always do factory data rest . And start it over like it’s new phone. If someone else doesn't chime in with how to fix it in its current state
