01-17-2023 10:54 AM
I have changed phones from a iPhone 6 to an iPhone 8. When I switched the SIM card. The iPhone 8 display the following message.
SIM Not Supported
The SIM that you currently have installed in this iPhone is from a carrier that is not supported under the activation policy that is currently assigned by the activation server. This is not a hardware issue with the iPhone. Please install another SIM from a supported carrier or request that this iPhone be unlocked by your carrier. Please contact Apple for more information.
01-18-2023 12:01 PM
By any chance was the old SIM still in the phone? Or does settings, general, about, still show the carrier information? And in settings, general, about and scroll down a bit, does it say this?
If yes, it is unlocked.
If no, it is carrier locked.
01-18-2023 11:28 AM
Did you find the name of the carrier in the Settings of the phone as instructed?
You will need to go to that carrier to have it unlocked.
01-18-2023 07:56 AM
The only way to fix this has been mentioned. You'll need to contact the previous carrier od the device to get it unlocked.
01-18-2023 07:47 AM
How did you fix it?
01-17-2023 01:15 PM
There is a slim chance it could be locked but you can go to Setting>General>About>then scroll down to bottom of page and if it shows a carrier name then it is locked.
You will need to go to that carrier to have it unlocked for free.
If it says No SIM Restrictions then it is unlocked.
01-17-2023 10:57 AM
@pauljohncooney sound like the iPhone was locked. Has it been used on another provider? which provider?where you got it from?
check with the provider you got the iPhone from and ask them to help unlock
01-17-2023 10:56 AM
also try rebooting your phone first
01-17-2023 10:55 AM - edited 01-17-2023 10:58 AM
It looks like your new phone is locked. iPhone 8 is from 2017 just when Canada declared all phones must be unlocked but yours might be not.
Who was previous service provider?
Can you try any other SIM in this phone?
